need help in 12 hour format digital clock
luckyveloso
Joined Jan 21, 2010
6
badly need help in analyzing or implementing the circuit diagram of the hour part in 12 hour format clock using 74ls192 or 74ls90...tnx
luckyveloso
Joined Jan 21, 2010
6
the seconds and minute part goes well, it counts from 0 - 59...the only problem is the hour, coz it dont start at 01...instead it start from 00 then ended at 12, then back to 00...
beenthere
Joined Apr 20, 2004
15,819
It's all on the data sheet. Every logic IC has one. It explains all the dunctions and how to make use of them. Google using "74ls192" as the search term.
sgardner025
Joined Nov 5, 2009
79
With the 192 you could tie P0 high and P1-P3 low on the 1's place hour counter and tie P0-P4 low on the 10's place hour counter. Then you could use some decoding to take the PL inputs low during the next low to high clock transition on the 1's place hour counter.
luckyveloso
Joined Jan 21, 2010
6
can you you show me the diagram or how you decode the PL inputs? i've been working this one for already a one week now and still i couldn't figure it out...pleaseee...thanks...
Wendy
Joined Mar 24, 2008
23,812
Use the LOAD as a reset, and the counter will go where you want. You might also take a look at the 4029, a very similar device. Pinouts are different, but it does exactly the same job.
sgardner025
Joined Nov 5, 2009
79
The PL inputs of the 74192 are active low so you need to take them from high to low whenever you want to load the counter. I attached an example where a binary 1 would give a low output. The msb would be at the top on the nor. You can use this method to decode the outputs of the counters. You just have to make it so that only the desired inputs give the output that you need.
