That's the green coating on the board (solder resist) that is used to cover areas of the board that do not need to be soldered and is not an adhesive.Also wanted to ask if this repair paint would work? After it cured just scrap away a small area around hole for solder to attach on. I never tried this stuff, but got it to repair boards.
No, not as low as 600mV. We will use the new ic after checking all the remaining components and repairing the connections.So there should be continuity there or there shouldn't be?
No, not yet. Give me a few minutes to check some things out.So should I work on putting U2 back in?
I am concerned about the connections that you say do not go anywhere. Are the rings around a hole ?which is just one of those free floating rings that dont connect to any circuits.
