I have labeled the test points on the attached image.
Timescope
If possible, measure the voltage across them. The negative terminal of the capacitor is identified with a line along the side.Also what would you like me to do with C21 and C22?
That is the +15v supply to the " IN /OUT" circuit that interfaces the microprocessor with the other circuits.Also had a question about what "+15_I/O" means.
Timescope
