Need Help Enabling External 0–5V Control on JIHPUMP KY300EL-I/104KA Peristaltic Pump
Reloadron
Joined Jan 15, 2015
7,979
The 2.7 volt offset was to allow the control voltage to reach5.0 volts when the max from the controller was at 3.3 volts. Ofcourse, actually the added offset would only be 1.7 volts. It seems that there was a slight error on the math earlier. Thanks for catching the error!
OK but if we offset using 1.7 volts don't we lose the 0.0 volt low end. Meaning if for example I have a pump running between 0 and 100 RPM. Using a linear scale if I use 0 to 5 volts for my speed control I get 50 mV per 1.0 RPM. With a bottom end of 1.7 volts I start at about 34 RPM. I lose about 1/3 of my range and can't get any lower. How does that work out?
Ron
panic mode
Joined Oct 10, 2011
5,470
exactly... using only offset is a crutch, since portion of range is lost.
one could argue that at least it makes the gap at the low RPMs where motor power/cooling are limited as well.
