Need help electrical engineering
elerner
Joined Dec 13, 2023
so I decorated my home with these types of light(image for reference only) before i went out. When i came back home it was already dark and the light was plugged in the socket but the switch was still off. But I saw it was glowing little, there was a small current in the wires of these light even if the switch was off. Can anyone explain this. Even if it is leakage current how can current flow through open switch, how can electrons jusy jump the switch in off state? Im new to all these stuffs.
MaxHeadRoom
Joined Jul 18, 2013
30,885
In some cases there are sets that have a LV Power supply that is under power when plugged in, The Switch, often just initiates the electronics.
What you are seeing is very low leakage current,
Mine is this way,
Dodgydave
Joined Jun 22, 2012
11,395
Does it glow when its unplugged from the socket?
WBahn
Joined Mar 31, 2012
33,353
Is the light switch on of these that glows when it is off so that you can find it in the dark? If so, then how those work is by passing a small current through the load when switched off.
MrAl
Joined Jun 17, 2014
13,901
The funny thing about LEDs that we don't usually see with incandescent bulbs is they can glow a little even with a very tiny current. I think they used to call it "first light" but not sure if that phrase is in vogue any longer. That simply means that even a very small current can cause an LED to light up a little and so even a small leakage current can make it look like the switch is 'on'.
I've measured leakage in switches in several applications, but to be sure what is causing this you'd have to do a few measurements. To start, what is the actual current through the LEDs. You'd have to measure that.
