Hi everyone,
I'm working on a personal project to build a Transcranial Electrical Stimulation (TES) device, which can support tDCS (direct current stimulation) and potentially tACS (alternating current stimulation).
My goal is to understand and build a safe and functional prototype that can output 0.5–2 mA of current through scalp electrodes, with basic safety features, waveform control (especially for tACS), and session timers.
What I am looking for :
1.A complete understanding of the circuit blocks required for TES
2.List of essential components (op-amps, current source ICs, microcontrollers, etc.)
3.Schematic or references for building:
4.A constant current source
5.A microcontroller-controlled waveform generator (for tACS)
6.Safety features like current limiting, timer cutoff, etc.
7.Suggestions for electrode interface (types and connection method)
8.PCB design tips for compact and safe layout
Important constraints :
1.Max output current: 2 mA
2.Needs to be current-controlled (not voltage-controlled)
3.Compliance voltage: 15–20V max to overcome skin resistance
4.Safe for scalp usage (with all required protections in place)
I've read that TES uses common placements like F3-Fp2 (10-20 system), and I'm using saline-soaked sponge electrodes or rubber electrodes with gel for skin contact.
Any help with schematics, safety guidance, or component suggestions would be massively appreciated. If you've built or worked on anything similar (like tDCS, tACS, TENS, EMS), I’d love to learn from your experience.
