Need datasheet for Murata CD1450C module
fataba
Joined Aug 31, 2024
5
I'm currently working with a DC-DC converter labeled as CD1450C. We have industrial power supply that has this component. Dimension is 50x50 mm. But I am unable to find its datasheet or detailed specifications.
The one I have is damaged and I need to replace with an equivalent one. I know it's an obsolete part. The only way probably is to contact murata which I've already tried but they're not responding. Even if anyone can give anything from Murata's CD series converters like CD1448 or something closer that'd also help.
35,327
Maybe it was a custom design for an OEM (Original Equipment Manufacturer).
Do you know the input and output voltage and current requirements?
fataba
Joined Aug 31, 2024
5
Input is mains rectified DC ~310vdc, one output is isolated 12volt, other pins are unknown
