The expensive current probe engineering has is for a pretty expensive Teledyne LeCroy scope. I think the probe is like $3K. Only problem is it is a 20A probe, so I can only compare our A622 using a driver with a small inrush. My thought is just that the A622 probe will capture most of the inrush except maybe the initial peak that occurs in 10uS or faster. The energy under the curve for that brief time is going to be relatively small when compared to the total joules of a driver inrush that has a 10%-10% rise-fall time around 2-3mS. We have seen drivers with lower peak inrush currents, but longer duration cause more relay contact welding than drivers with much higher inrush currents, but shorter durations less than 1mS.Note that rogowski coils are really not that expensive - I think we bought two at ~$1500 each not long ago (unfortunately the company tanked a few short months later). This is really chump change when working at a large corporate company, as I believe you are. I also had to demo one to convince the boss that I needed one to get the job done properly before he'd shell out the cash. I thought that was a reasonable request. It was an easy sell once he saw the side-by-side comparison.
