Need charger solution - Board
Deleted member 618306
Joined Dec 31, 1969
Hi There,
I am need of a circuit that will work as expected. Please check the attached image for information.
Joined Dec 31, 1969
KeithWalker
Joined Jul 10, 2017
3,625
This will be a integrated one right? Can i use this instead of two modules?
You can but float charging LiPo batteries reduces their life span. It would be far better to put an on/off switch between the battery and the boost convertor and turn it off when the battery is being charged. You can not do that with the integrated unit.
LesJones
Joined Jan 8, 2017
4,544
Have you thought of using one of the power banks that are sold for recharging mobile phones etc. It may be possible to drop the output voltage from 5.0 volts to the 4.5 volts that you require if you can find data on the ICs used in them. If not you could put a Schottky diode in series with the output which would drop the 5 volts down to about 4.5 volts.
Les.
