Necessary steps to design Mini Audio Amplifier Circuit With BC547
Audioguru again
Joined Oct 21, 2019
6,826
I wrongly calculated the p-p voltage for 25mW, not 20mW.
The peak voltage is half the peak-to-peak voltage. The peak voltage is 1.414 (the root of 2) times the RMS voltage. The peak-to-peak voltage is 2 x 1.414 times the RMS voltage. 2 x 1.414 is 2.828.
Bordodynov
Joined May 20, 2015
3,428
Here is a power of 29 mW at a supply voltage of 3 V and thus small distortions. Signal amplitude at 15 mV input, 1.36 V output amplitude. As output transistors I took transistors with low saturation voltage and increased power dissipation.MMM.png
Audioguru again
Joined Oct 21, 2019
6,826
Many people want the loudest peak power of music into their earbuds or earphones to be 20mW at low distortion, but some headphones will be louder and others will be less loud. Your assumption of 5mW is probably not loud enough. It might be like faint background music. In Google, look up Cmoy Headphone Amplifier that uses modern opamps, not old-fashioned discrete transistors.
