NAND gate TTL - How it works
pj33000
Joined Feb 1, 2021
11
I am studying digital electronics and I am a bit confused about the saturation conditions of the bjt.
I knew that the bjt saturates when the Vce is close to 0 and Vbe >= 0.7. However, when I was reading about TTL I got confused.
Can someone give me some intuition and explain me why in the case where both inputs are high, why Q2 and Q4 saturate and Q3 is OFF please.
I believe I understand something wrong because I cannot see how the saturation conditions are met.
If there is a more intuitive way to think about this please let me know.
Thank you
LesJones
Joined Jan 8, 2017
4,544
Think about where the current through R1 goes when both inputs are high. (Tip. Think about the way you test a transistor using the diode test mode on a multi meter.)
Les.
pj33000
Joined Feb 1, 2021
11
Think about where the current through R1 goes when both inputs are high. (Tip. Think about the way you test a transistor using the diode test mode on a multi meter)
For Q3 I know it must be OFF but not sure why. But you give me a more intuitive explanation about the saturation mode please? Because I know they must be in saturation but not sure why.
Les.
I know that Q1 is in reverse mode, current flow from R1 to Q2 (don't know whether current is large or not)
pj33000
Joined Feb 1, 2021
11
For homework, you need to show your work before we can offer any hints. You'll learn more that way...
I don't know how to start calculating. Current flows from R1 to Q2 but I don't know how to calculate how much. Also I am not sure whywhy Q3 is OFF
38,945
You have the value of the resistor, you should know the value of the nominal diode (transistor junction) forward voltage drop, and the supply voltage.
From that you can calculate the current using Ohm's law.
After that calculation, you should be able to determine why Q3 is off.
You do know Ohm's law I would hope.
pj33000
Joined Feb 1, 2021
11
It may help to draw just the path from V+ through the resistor, and the transistor junctions to ground.
I have been thinking of the simulation given above. In that case Q1 is reversed thus current flow from R1 to Q2. Q2 is saturated as Vbe >= 0.7V and Vce is close to 0V so current flows to Q4. Given that the forward bias voltage of the diode is almost 0.7V then Vb3 across Q3 is 0.1V thus Q3 is OFF and Q4 is ON for similar reason.
So current flows from R2 to Q2 to Q4 and ground.
How can I calculate the voltage va as shown in the diagram? I mean the transistor is reversed which formula helps to calculate that?
38,945
Yes, Q1 is off as a transistor.
But current can flow through Q1's base-collector junction, which is now forward biased (draw in the NPN base-collector junction direction).
pj33000
Joined Feb 1, 2021
11
You mean it is forward bias thinking of the Ebers-Moll model?
If yes, how can I calculate the current and the voltage drop? Sorry that the questions are elementary but I am confused as the notes that I have are not that good.
pj33000
Joined Feb 1, 2021
11
You don't need the model.
The base-collector junction just looks like a forward-biased silicon junction diode, the same as the base-emitter junction.
Ok, but how can I solve the circuit. I mean I have a 5V source, R2 a diode but no ground.
Explain this please to clear everything out as well as how can I know by inspection that a transistor is saturated or OFF as done here:
https://www.vedantu.com/question-an...lass-12-physics-cbse-603774e71bab3a5dc7202907
Which just by inspection it says that T3 is saturated (annoyingly all the sources of that I found do this without explaining why it saturated as no calculations are done)
