mystery variable in code
Killerbee65
Joined May 15, 2017
248
Hello all,
So I'm back with another one of my professor's assignments. This time I'm supposed to calculate most of the information on a pay stub such as, base pay, overtime, taxes, etc. I'm currently reverse engineering my professor's code and came across this variable in a function that doesn't seem to have a value but is used as if it does, can someone please explain how the variable "gross" works?
also, can someone show me how to paste code correctly from visual studio? I'm new to it and don't really know how to use it.
C++:
#include <iostream>
#include <iomanip>
using namespace std;
    function that computes a pre-tax IRA (Individual Retirement Account) deduction from gross pay prior to computing the withholding amount
    if gross pay is greater than $400 and less than $500, deduct 5%
    if gross pay is $500 or more, deduct 10%
    ira = gross * percent_deduction;
double computeIRA(double gross);
    function that computes federal withholding
        0 dependents - withhold 28% of gross pay
        1 dependents - withhold 20% of gross pay
        2 dependents - withhold 18% of gross pay
        3 dependents or more - withhold 15% of gross pay
double computeFedWithholding(int dependent, double gross);
int main()
    //declaring variables
    int hrs = 0, reg_hrs = 0,  ot_hrs = 0, dt_hrs = 0, dependents = 0;
    double payRate = 0, regPay = 0, otPay = 0, dtPay = 0, grossPay = 0, netPay, withholding;
    const short unsigned FULL_TIME = 40;
    const short unsigned OT_MAX = 50;
    const double OT_RATE = 1.5;
    const double DT_RATE = 2;
    const double NO_DEPENDENTS = 0.28, SINGLE_DEPENDENT = 0.20, TWO_DEPENDENTS = 0.18, THREE_DEPENDENTS = 0.15;
    bool isValid = false;
    // Get pay rate
    while (!isValid)
        cout << "Enter your hourly rate of pay: ";
        cin >> payRate;
        isValid = payRate >= 0;
        if (!isValid)
            cout << "Error: the pay rate must be >= 0." << endl;
    isValid = false; // reset the flag
    // Get hours worked
        Note: some people get confused with line 73 so I show here any more explicit
    while (isValid == false)
        cout << "Enter the number of hours worked: ";
        cin >> hrs;
        isValid = hrs >= 0;
        if (!isValid)
            cout << "Error: the number of hours must be >= 0." << endl;
    // Get hours worked
    do
        cout << "Enter the number of dependents: ";
        cin >> dependents;
        isValid = dependents >= 0;
        if (!isValid)
            cout << "Error: the number of dependents must be >= 0." << endl;
    } while (isValid == false);
        NOTE: because we validate above we can rest assured that all calculation that follow should work-out
    // Compute DT hours
    dt_hrs = hrs - OT_MAX;
        Compute OT hours
        if we have double hours  ot_hrs will be the difference between max OT and full-time (10)
        else use the same calculation from last week
    ot_hrs = hrs - FULL_TIME;
    if (dt_hrs > 0)
        reg_hrs = FULL_TIME;
        ot_hrs  - FULL_TIME;
    else if (ot_hrs > 0)
        dt_hrs = 0;
    else
        dt_hrs = 0;
        ot_hrs = 0;
        reg_hrs = hrs;
    //calculating the gross pay
    regPay   = reg_hrs * payRate;
    otPay    = ot_hrs * payRate * OT_RATE;
    dtPay    = dt_hrs * payRate * DT_RATE;
    grossPay = regPay + otPay + dtPay;
    // compute
    double ira = computeIRA(gross);
    // IRA deduction
    double modifiedGross = gross - ira;
    // calculate the withholding
    withholding = computeFedWithholding(dependent, modifiedGross);
    // calculate the net pay
    netPay = modifiedGross - withholding;
    //displaying to the user the number of hours they worked, their hourly pay rate, and the calculated gross pay
    cout << endl << fixed << showpoint << setprecision(2);
    cout << "Regular hours at $" << payRate << " = " << reg_hrs <<  endl;
    cout << "Base pay at regular rate = $" << regPay << endl;
    cout << "Overtime hours at time and a half = " << ot_hrs << endl;
    cout << "Overtime pay at time and a half = $" << otPay << endl;
    cout << "Overtime hours at double time = " << ot_hrs << endl;
    cout << "Overtime pay at doulbe time = $" << otPay << endl;
    cout << "Federal tax bracket with " << dependents << " dependents is " << setprecision(0) << noshowpoint << taxRate * 100 << "%" << endl;
    cout << setprecision(2) << showpoint;
    cout << "Gross pay = $" << grossPay << endl;
    cout << "IRA contribution with " << grossPay << " in gross pay = " << ira << endl;
    cout << "Modified Gross pay = $" << modifiedGross << endl;
    cout << "Federal tax withholding with " << dependents << " dependents is $" << withholding << endl;
    cout << "Net pay = $" << netPay << endl;
    // display lab 5 specific display message
    return 0;
    double ira = 0;
    if (gross > 400 && gross < 500)
        ira = gross * 0.05;
    else if (gross >= 500)
        ira = gross * 0.10;
    return ira;
    double taxRate, withholding;
    switch (dependents)
    case 0:
        taxRate = NO_DEPENDENTS;
        break;
    case 1:
        taxRate = SINGLE_DEPENDENT;
        break;
    case 2:
        taxRate = TWO_DEPENDENTS;
        break;
    default:
        taxRate = THREE_DEPENDENTS;
    withholding = grossPay * taxRate;
    return withholding;
Moderator edit: added code tags
WBahn
Joined Mar 31, 2012
26,398
It would be quite helpful if you would format the code to make it organized and readable and also say where the variable you are concerned about is first used.
If you are talking about the part of the code are the IRA deduction is calculated, then I imagine that if you look at the few lines of code before it you will see where the professor probably made a mistake and what they likely meant.
Killerbee65
Joined May 15, 2017
248
I mentioned in the post I didn't know how to format it and telling you which line would just be a waste of time. I probably should have said something like "at the bottom" or something. and the reason I didn't touch is is for reference purposes if the problem was found.
on the function all the way at the bottom it says "double computeIRA(double gross)" I'm good with knowing that bc I know now "gross" resides in the function, what trips me up is the fact "gross" doesn't have a value so how did he multiply it by 0.05? and in the next function, "gross" isn't even used. When I replicate the code and call it "fed_withhold(gross)" it says gross wasn't declared but I made sure to format my code so that it is similar to my professors (as a test to see if I could figure out how it would work) and whats even more confusing is when HE calls it he multiplies it again but gross doesn't have a value. I made sure the code words so either my calculations are wrong or there some black magic at work :)
Killerbee65
Joined May 15, 2017
248
You mean enclosing the code with code tags like this:
[code=CPP]
... your code goes here
[/code]
I'm not sure, when I coded for Arduino it would have an option to copy and paste code for forums and it would be formatted, not sure how to do that with visual studio, let me see if it works.
C++:
#include <iostream>
#include <iomanip>
int main()
// Get pay rate
while (!isValid)
cin >> payRate;
if (!isValid)
// Get hours worked
cin >> hrs;
isValid = hrs >= 0;
if (!isValid)
// Get hours worked
do
cin >> dependents;
if (!isValid)
// Compute DT hours
Compute OT hours
if (dt_hrs > 0)
ot_hrs - FULL_TIME;
dt_hrs = 0;
else
dt_hrs = 0;
ot_hrs = 0;
reg_hrs = hrs;
// compute
// IRA deduction
return 0;
double ira = 0;
ira = gross * 0.05;
ira = gross * 0.10;
return ira;
switch (dependents)
case 0:
break;
case 1:
break;
case 2:
break;
default:
return withholding;
Moderator edit: using code=CPP
Killerbee65
Joined May 15, 2017
248
C++:
#include <iostream>
#include <iomanip>
int main()
// Get pay rate
while (!isValid)
cin >> payRate;
if (!isValid)
// Get hours worked
cin >> hrs;
isValid = hrs >= 0;
if (!isValid)
// Get hours worked
do
cin >> dependents;
if (!isValid)
// Compute DT hours
Compute OT hours
if (dt_hrs > 0)
ot_hrs - FULL_TIME;
dt_hrs = 0;
else
dt_hrs = 0;
ot_hrs = 0;
reg_hrs = hrs;
// compute
// IRA deduction
return 0;
double ira = 0;
ira = gross * 0.05;
ira = gross * 0.10;
return ira;
switch (dependents)
case 0:
break;
case 1:
break;
case 2:
break;
default:
return withholding;
WBahn
Joined Mar 31, 2012
26,398
The "double computeIRA(double gross)" is a function definition and the "gross" is the name of the parameter that is passed into the function. So when it is called with, say
myContribution = computeIRA(monthlySalary*12)
the value obtained by computing monthlySalary*12 is passed to the function and copied into the local variable "gross".
Where the undeclared parameter is coming from is line 118 and 121 (in your original post as it currently stands).
Killerbee65
Joined May 15, 2017
248
I think I understand, so you're saying that "gross" on line 121 is the local variable and just a result of the calculations made in the computeIRA function? also, what does ira represent on lines 118 and 121?
Killerbee65
Joined May 15, 2017
248
So this is my attempt at the code, sorry if it's hard to read I had to rearrange a lot of stuff but what I mainly want to focus on is the number of dependants or "dep", on line 94-ish(i had a few lines of text before the code)I have "dep" at the end of the output string and I want it to display the number of dependants (which is z) the user inputs, as well as the percent associated with it so 0 dependants is 28% 2, is 20%, etc. at the very bottom is a function I used to calculate the withholding amount. Not exactly sure if I need to change anything else in the code, the way I wrote it is in steps so I assume if I change one thing the rest will change like a domino effect and I don't have to go back and change like 30 different things but let me know if you need clarification or if you notice something.
C++:
#include <iostream>
int main();
double fed_withhold(double dep, double gross);
double IRA_deduct(double gross);
//dependants
    double dep = .28;
    double dep1 = .20;
    double dep2 = .18;
    double dep3 = .15;
    int y, z;
    double x, total, dpay;
int main()
    const int hours = 40,  dhours = 50;
    const double prate = 1.5, drate = 2;
    int reg_hrs = 0, ot_hrs = 0, dt_hrs = 0;
    double withholding;
    while (!isValid)//ask for pay rate and validate
        cin >> x;
        isValid = x >= 0;
        if (!isValid)
            cout << "Error: the pay rate must be >= 0.\n";
    }isValid = false; // reset the flag
    while (isValid == false)//ask for hours worked and validate
        cin >> y;
        isValid = y >= 0;
        if (!isValid)
            cout << "Error: the number of hours must be >= 0.\n";
    total = x * y;//pay rate * hours to give pay
    int overh = y - hours;// subtracts total hours by overtime (40 hours) to get overtime hours
    double overT = overh * prate * x; // multiples overtime hours by pay rate increase and by pay rate
    double bpmax = hours * x;//max base pay possible
    double gpay = bpmax + overT;//max base pay with overtime (gross pay)
    int althours = dhours - (hours + 1);//overtime hours
    double opmax = althours * prate * x;//overtime hours * over time pay rate increase * pay rate
    int doubh = y - dhours;// subtracts total hours by doubletime (50 hours) to get doubletime hours
    double dover = doubh * drate * x; // multiples overtime hours by double pay rate increase and by pay rate
    dpay = bpmax + dover + overT;// calculates the max base pay + double time pay + overtime pay
    double ira = IRA_deduct(gpay);
    double modifiedGross = gpay - ira;
    withholding = fed_withhold(dep, modifiedGross);
    double netPay = modifiedGross - withholding;
    cout.precision(2);
    if (y > hours && y <= dhours) {
        cout << "\nHours worked = " << fixed << y;
        cout << "\nHourly rate of pay = $" << x;
        cout << "\nbase pay = $" << bpmax;
        cout << "\nOvertime pay= $" << overT;
        cout << "\nGross pay = $" << gpay;
    else if (y > dhours) {//double time "route"
        double alt_overh = althours * prate * x;
        //validate number of dependants
        do
            cin >> z;
            isValid = z >= 0;
            if (!isValid)
                cout << "Error: the number of dependents must be >= 0.\n";
            double dpay_alt = gpay + dpay;
            cout << "\nOvertime hours= " << althours;
            cout << "\nfederal tax brackets with " << z << " dependents is %" << dep;
            cout << "\nFederal tax withholding with " << z << " dependents= $" << dpay;
            cout << "\ndoubletime hours= " << doubh;
            cout << "\nnet pay= $" << dpay_alt;
    else if (y <= hours) {
        cout << "\nbase pay = $" << total;
        cout << "\nGross pay = $" << total;
    switch (z)
    case 0:
        taxRate = dep;
        break;
    case 1:
        taxRate = dep1;
        break;
    case 2:
        taxRate = dep2;
        break;
    default:
        taxRate = dep3;
    withholding = dpay * taxRate;
    return withholding;
    double ira = 0;
        ira = gross * 0.05;
        ira = gross * 0.10;
    return ira;
