I am wiring up a very simple circuit just to experiment with transistors. This consists of the emitter pin connected to +5V, the collector pin connected a resistor and LED which are in turn connected to ground, and the base pin to a wire which I attach to either +5V or 0V.
I'm using NPN transistors which are rated for 1.8W and PNP transistors rated for 300 mW.
After I leave my transistor connected for a while, I find that it gets very hot. Why is this and how can I fix it? Should I put a resistor on the base pin? Could I possibly have the transistor hooked up backwards and would this matter?
Edit: Here is a quick schematic I made of the circuit.
