As far as I know, I do not have any old tutorials from Microchip in my data book collection.Is assembly Language for Microchip, but I see that Bertus has provided us some info
I looked in my 1984/1985 Unitrode databook and did not find your part. I did not find any numbers that were even similar.I see that you have a Unitrode data book. I have tried to find data sheets for the Unitrode USD5096F Schottky diode, but it has proven to be hard to find through Google. I would very much appreciate if you could scan a few pages on this schottky rectifier diode.
That is strange. The date code are 83 and 84. I even purchased some NOS from http://www.electronicsurplus.com/unitrode-usd5096f-diode-35amp-35v-piv .I looked in my 1984/1985 Unitrode databook and did not find your part. I did not find any numbers that were even similar.
Do you have any idea when the part might have been made? You can look at the date codes on IC's in your unit if this is a repair.
Can you give me more information? A description and when the part was made would help. If you are not sure of this information, tell me where the part is used and what numbers are printed on the chip so we can get the date code.Mostek MK6049N Datasheet needed Please.
I have done an inventory of my collection of old data books. It numbers about 600 books at this time. There are still some stragglers that need to be added when I get the time.
See this thread for background:
http://forum.allaboutcircuits.com/t...onductor-linear-applications-handbook.100301/
Since this is the Electronics Resource Forum I am going to make an offer to members of the AAC Forums. I am willing to scan a limited number of obscure data sheets (not entire data books) from my collection. All I ask is that you do not request data sheets that are already available on-line.
-- RichardO
http://www.datasheetarchive.com/dlmain/Datasheets-110/DSAP0010031.pdfCan you find the data sheets for the Motorola MC1302 (7 stage divider, may be MC1302L)? It would be under the Consumer section in the Motorola Linear IC databook 1979 or 1980-81 I believe. It appears to be a part that was only in production for a year or two.
I have 36 directories: 0-9 and A-Z. Data sheets go into the appropriate directory alphabetically, by part number. If there are a lot of data sheets from a single manufacturer then I add a directory for that manufacturer (in the directory for that manufacturer alphabetically) and move and/or copy the files there.PD: I have a few gb of datasheets. Some of them for the same chip but different manufacturers. But it's very messy to order them correctly!
I do the same.I just add the name of the manufacterer in the filename.
One set of data sheets that I've never been able to find is; the old Mullard OC prefix germanium transistors.I have done an inventory of my collection of old data books. It numbers about 600 books at this time. There are still some stragglers that need to be added when I get the time.
-- RichardO
Wow. I don't think I have even _seen_ Mullard data.One set of data sheets that I've never been able to find is; the old Mullard OC prefix germanium transistors.
I have some specs on Mullard OC transistors. What would you like to know?One set of data sheets that I've never been able to find is; the old Mullard OC prefix germanium transistors.
