Multivibrator circuit with solution
Rumination
Joined Mar 25, 2016
74
The figure shows a multivibrator circuit consisting of: an integrator, an Schmitt trigger and a comparator. When the circuit is started up, it delivers a periodic triangular signal OUT_Trekant and a periodic square signal OUT_Firkant.
Operational amplifiers can be considered ideal, with L+ = 10V and L- = -10V. The circuit includes six diodes that can all be considered ideal, with an ON voltage of 0.7V. These diodes together with R3 form a limited circuit, which ensures a well-defined value size of the output voltage Vout_Firkant.
1) Determine the maximum positive and negative output voltage swing of the signal OUT_triangle i.e. Vout_Trekant_pos and Vout_Trekant_neg.
2) Determine the triangle signal switching frequency: f_out_Trekant.
The deadline is tomorrow night.
The given values:
R1 = 18,6 KΩ.
R2 = 18,2 KΩ.
R3 = 100 Ω.
R4 = 10 KΩ.
C1 = 0,003216 μF.
Ain_comp = 3,37 [V].
Rumination
Joined Mar 25, 2016
74
We know that L+ = 10V and L- = -10V. And that
10 V = Vout_Trekant_pos - 0,7
Vout_Trekant_pos = 10 V + 0,7 = 10,7 V.
- 10 V = Vout_Trekant_neg + 0,7
Vout_Trekant_neg = -10 V - 0,7 = -10,7 V.
Or am I completely wrong?
I don't understand question b.
