hey I'm making an analog PID board that is controlled by a pic24. but i'm having problems with the power supply. the parts that work are the PID +16v and -16v, my analog pwm 0v and 16v, but my mcu supply is the problem I can power it from the same source as the PID/PWM circuit (using a voltage regulator seeing that the pic uses up to 3.6v, 250mA). My problems are the following:
1. I don't know if I can use the same GND as the I power the pic from a usb or if I have to the usb's gnd.
2. the same as above but for the pickit3
I want to prioritize the pickit's supply (cause I don't want to interfere in the programming) over the usb and usb's supply over the PID/PWM's supply. Using the datasheet I know how to switch from a power supply to usb supply. I'm believe that when there is power on Vself, usb supply is turned off, so to do what I want i'd have to add another pnp (between Vself and the node at the transistor base), am I correct?
