I'm a relative newbie to this forum. In a previous thread I inquired about a Hit and Hold Solenoid driver (https://forum.allaboutcircuits.com/threads/hit-and-hold-solenoid-driver.173857/).
I have built this little circuit on a breadboard to test it out before I put it on a PCB stripboard (also, my soldering isn't too good yet, so the breadboard really helps me get things figured out)!
Anyway, after assembling the breadboard I used a "cheap Harbor Freight" multimeter to check the voltages.
I have a 13.8V wall wart that is supplying power to the board. The idea of this circuit is for the "output" (bottom connector)
to "hit" a little CO2 solenoid with about 12V at turn-on to energize and open the valve. After about 25-30ms, the
voltage decays to about 6V to "hold" the solenoid valve open. By halving the voltage, the power dissipated in the
solenoid is reduced by 75% - so the solenoid should last a really long time.
When I use the "cheap" multimeter to measure output (without the solenoid connected) it reads 13.8V (same
as the direct voltage from the wall wart. After experimenting a while (different multimeter, checking connections,
trying different resistors) I got pretty consistent results (always 13.8V).
Even when I just put a 330ohm resistor in-line with my wall wart, I still got 13.8V. I would have guessed
that I would get about 6V, but I don't think I'm understanding how the multimeter works. I guess the
impedance, etc., of the multimeter has a big effect, yes?
Finally, I just connected the output to the solenoid, and lo and behold, it energized (so I'm assuming it got
a long enough "hit" of over 12V), and then I probed the solenoid connection with the multimeter and read
about 6V!
Okay, so I guess I have a really crappy multimeter, and a poor understanding of how the multimeter works.
Can someone explain my measurements, and recommend a "good" multimeter that will provide better results?
FYI, the resistor is 330ohm, cap is 680 micro farad.
Even the cheap units work okay to tell you if 110V is "on" or "off", but this is the first time I've tried to build
a "time-dependent" circuit and am in need of a better multimeter.
Thanks a lot!
Gregg G.
about 6V!
Thanks a lot!
Gregg G.
