Multimeter wrong results
en.ahkami
Joined Dec 18, 2025
7
Hi I have a multimeter that doesn't show accurate reading in resistor and doesn't read anything in capacitor at all.
I measure 5.6 kohm resistor and it shows me 2.1 kohm
In capacitor mode it repeadly goes frome micro to millifarad with no reading.
Voltage reading is good. Battery is new.
How can I fix it. Is my multimeter broken?
Thank you
BobTPH
Joined Jun 5, 2013
11,678
Welcome to the forum.
Have you tried another resistor or measured that resistor with another multimeter?
What value is the capacitor you are trying? Have you tried a different one, preferably one in the range of .1 to 10 uF?
Are you sure the probes are plugged into the correct jacks?
Pictures of the components you are testing?
en.ahkami
Joined Dec 18, 2025
7
Hello, every resistor gives me wrong results, the capacitor is new and 2.2 microfarad, I'm sure the probs are fine because the voltage results are fine, I've tested 3300microfarad capacitor and it gave me 4.5 milifatad
BobTPH
Joined Jun 5, 2013
11,678
If the capacitor is electrolytic (polarized) try the connecting probes to the capacitor leads both ways.
Do the resistors always come out low by the same ratio?
twohats
Joined Oct 28, 2015
621
Check or relace the internal battery.
It may respond to a good cleaning, at least it will look better.
Good luck.........
P.S. A good name. You not the meter.
WBahn
Joined Mar 31, 2012
33,346
It is pretty likely that the meter is damaged and there is very little that can be done to repair these types of meters. Make a note of the functions that don't work and don't use those functions -- and avoid using the meter at all for things that are critical, as you don't know when those functions will fail.
en.ahkami
Joined Dec 18, 2025
7
Thank you. Last year it had become waterlogged, didn't turn on, I opened it and cleaned it, problem solved but I think It was broken right there.
rsjsouza
Joined Apr 21, 2014
430
The Victor/Vici VC97 is a very popular multimeter, and there are zillions of videos and discussions around the internet - there's even schematics!
Given this issue happens with the modes where the multimeter actually provides power to the component under test (resistance, capacitance), I would check the parts that are connected to the electrical path that performs these functions.
As for the decision of purchasing a new equipment, a small component tester is very versatile and a lifesaver in several cases. However, there are many low quality testers around the internet and you need to carefully look at reviews that can help you separate the wheat from the chaff. Many years ago I bought this tester from this seller (no commercial interest from this) and it works incredibly well, but keep in mind these products are constantly changing.
You might want to consider investing in both - a new multimeter and a tester. The reason for considering a new multimeter is related to what types of measurements you need to do. If you do a lot of repairs, you will have to frequently measure resistances directly on the equipment/board or or parts fitted to the board. The multimeter is better suited for those types of measurements since it usually has input protection in case the equipment/board has residual charge that would otherwise destroy your component tester.
Nowadays the offers for moderately decent multimeters at reasonable prices is very broad - my favourite very low cost meter is the Richmeters RM113D which has reasonable electrical and mechanical robustness. I have been using mine for years now. Others could be the Uni-T UT123 and a bit more expensive models such as Bside ZT-Y, Aneng AN870 (Richmeters RM219), Kaiweets HT118A are also reasonably good meters. I have no commercial interest on these recommendations.
Futurist
Joined Apr 8, 2025
952
As a kid I relied on something like this, quite amazing how it really was sufficient for most hobby projects back in the 70s even 80s.
