I was trying to measure pin 1 on my MAF sensor on my truck. It is supposed to read 2.2 to 2.7 K hertz. I put my setting to hertz. I put the red probe on pin 1 and the black probe on the negative terminal of the battery. It read 0. I removed the negative probe. It read 2.5 K hertz. I pushed the throttle up and down. The reading went up and down from 2.2 to 5 K hertz, showing my my sensor was working perfectly. What I don't get is why I had to use just the red probe? I was told you need the ground to the negative terminal. But this turned out not to be the case. Does anybody know why?
