Frequency Changes Affecting The Output Voltage Of 555 Seen on Multimeter
phantomII
Joined Dec 23, 2019
17
Hi, I'm trying to make this circuit and have some problems. I replaced the 180k resistor with 200k POT. When I increase the frequency, the voltage value that I measure with multimeter (no true rms spec.) increases too. I have observed same stuff in Proteus but the amplitude of the wave stays same in Proteus' oscilloscope . My question is this; what I measure with multimeter and which data is reliable?
DickCappels
Joined Aug 21, 2008
10,661
There are various kinds of voltmeters. I assume what we are talking about digital voltmeters. Few until recently measured RMS voltage and many of those that do today are not intended for wideband use. Meters without RMS converters (RMS-to-DC) use a diode or ideal diode detector to convert the incoming AC to DC. Apparently you are demonstrating that the detector in your meter is not wideband.
Since you are changing the duty cycle when you adjust the variable resistor that will probably have a large effect on measurements with most types of digital voltmeter. That, combined with the frequency response of the transformer can make for huge changes in the measurements.
In other words, what you observe is not a surprise.
dl324
Joined Mar 30, 2015
18,465
An oscilloscope will give you better information about varying waveforms than a DVM. The DC setting on a DVM is for measuring DC voltage. If the measured voltage is alternating, who knows what the DVM is measuring. Even an AC measurement would be dubious.
The voltage is varying as you change the frequency because the off time is constant and you're varying the on time and frequency with the pot.
phantomII
Joined Dec 23, 2019
17
I got it now but why Proteus' oscilloscope doesn't show the response of the transformer?
In real can i observe the voltage changes using oscilloscope?
phantomII
Joined Dec 23, 2019
17
You mean varying of the voltage is a normal process? so why i couldnt see the voltage changes on the oscilloscope in Proteus although it is seen in voltmeter?
dl324
Joined Mar 30, 2015
18,465
No. You're getting inaccurate readings because you're trying to use a DVM. If you use an oscilloscope, you'll see the waveform and the indicated voltages will be correct within the accuracy limits of the scope. Since you're using a simulation, the results are estimates.
DickCappels
Joined Aug 21, 2008
10,661
Maybe the transformer has a high enough magnetizing inductance so that the roll-off is far from the frequencies coming out of your NE555.
When using an oscilloscope you should get waveforms that are close to what you see in the simulations.
phantomII
Joined Dec 23, 2019
17
Thank you so much. Now somethings are clearer.
phantomII
Joined Dec 23, 2019
17
Thanks for giving help. I should get an oscilloscope as soon as possible
dl324
Joined Mar 30, 2015
18,465
You don't need to spend a lot of money. I bought a DSO138 for $20 from Ali Express after my daily use Tektronix Scope (15MHz SC502) stopped working. I have other scopes, but I use the DSO138 when I don't need better capabilities (higher frequency or more channels) to save wear and tear on my better CRT based scopes. IIRC, the DSO138 is good for up to 100kHz.
