Mr, I would like to use a 555 timer to alternate two blinking LED's,
stspringer
Joined Oct 1, 2019
81
Hello sghioto,
I was wondering if you could show a schematic of this circuit using P channel Mosfets, instead of N channel Mosfets. I have heard that you don't want to switch the ground side if you use a circuit in a motorcycle or a car, you want to switch the hot side.
Just curious to know your thoughts on this matter.
Thank You
sghioto
Joined Dec 31, 2017
8,765
Doesn't really make any difference since it's an independent circuit meaning not connected to any other electronics in the vehicle.
However using P channel mosfets will reduce the component count.
I'll draw up the circuit when I get home.
stspringer
Joined Oct 1, 2019
81
Thank you, interesting using pin 7, and resistor changes to the 555 timer too with cap and 100k resistor
I thought the larger Mosfets would be P channel Mosfets
stspringer
Joined Oct 1, 2019
81
Hello sghioto,
It's been awhile. Question: do I need decoupling capacitors on the 555timer to stop "ignition noise" on a motorcycle that may lock up the 555 timer? Thanks
