Moving to HTTPS
jrap
Joined Jun 25, 2006
1,128
I am beginning the process of moving the site to HTTPS. If all goes well, it should take about half an hour.
If you notice anything wonky with the site - it's likely because I messed up :)
djsfantasi
Joined Apr 11, 2010
9,237
Why? There are no state secrets being discussed here, no ecommerce being done. It just slows the site down. Maybe a couple pages, dealing with passwords... but why the entire site?
Not a criticism (yet) but I am curious.
jrap
Joined Jun 25, 2006
1,128
So far so good I think - If anyone noticed any pages where the "Secure" text isn't green, could you please paste the URLs in here? It means there is mixed-content, which we want to avoid.
Thanks!
Rob
spinnaker
Joined Oct 29, 2009
7,830
Security. You are sending passwords over the wire. If someone can install a sniffer they can get your password since it is clear text. They can then take over your account. If you use the same password elsewhere they could compromise that site too.
FYI the site appears to be hosed under Fluid. It appears as all text and you can't post. Somehow I was able to change formats. Going through preferences did not work. Please get that working. No rush, But I do hate the big orange. ;)
spinnaker
Joined Oct 29, 2009
7,830
Fluid is back and working again. Thanks so much for taking care of it so quickly.
Inbox appears to be working now too. Account settings was briefly not working so there was no way to change to fluid ;) but looks like all is good now.
Papabravo
Joined Feb 24, 2006
22,110
The text on the screen you go to when you hit the reply button is so small I can barely see it. Seems more like a bug than a feature. Your mileage may vary. [choke, puke]
jrap
Joined Jun 25, 2006
1,128
It's late and my brain is a bit fried from this change -- does this relate to https?
Papabravo
Joined Feb 24, 2006
22,110
I don't know if it does or not. It didn't behave this way the last time I was on earlier today. You tell me, you're the one in control.
EDIT: I know what is going on. I have to whitelist the use of javascript on the new URL. It was enabled for the http: version of the URL, and now the https: version is also whitelisted. Security can sometimes produce unexpected consequences.
djsfantasi
Joined Apr 11, 2010
9,237
In IT, any change at all is going to create more problems attributed to the change than is actually caused by the change.
That having been said, is anyone else experiencing having to scroll through an entire thread to get to the first unread post? It seems that whatever method was used to remember the last post read in s thread is no longer working.
I use Safari on an iPhone 6 running iOS 10.1.1 Build 14B100.
jrap
Joined Jun 25, 2006
1,128
The uploading issue should be resolved. If anyone could confirm, that would be appreciated.
Thanks!
jrap
Joined Jun 25, 2006
1,128
Fortunately these are small issues that can be fixed. Once they are resolved, we will be better off with this move to HTTPS.
I have not experienced the scrolling issue on Chrome (Desktop).
