Moving from normal bulbs to Leds, help needed
nic14
Joined Jan 8, 2014
12
Hello All,
I am looking for some advice to change the lights I currently have in my garage.
The garage at the moment is fitted with 14 (50W) regular spot light. Those give very poor light
and I believe they do use a lot of energy for the light they produce.
I asked around and I was told to replace those light with “LEDS”
I want to take this a step at the time to make sure I get it correctly so I will probably have many questions.
My garage is 7.3m by 3,7m and I use it also to shoot youtube tutorial videos for my projects,
so some extra light would probably benefit.
Question 1:
Can standard led strips of warm white of 12v be used, the type you can cut every 3 leds or must be a specific types?
Many Thanks for your help
Nic
dl324
Joined Mar 30, 2015
18,465
I'm skeptical of getting adequate lighting from LED strips. Is replacing the current spot lights with similar LED bulbs not an option?
ian field
Joined Oct 27, 2012
6,536
Hello All,
Question 1:
Nic
One of the UK DIY outlets is doing a special price on LED GU10s, they work on regular mains and only use about 3 - 4W.
38,813
I have used LED replacements for my recessed spotlights and they work well, giving out more light than the supposedly equivalent CFL bulbs.
ian field
Joined Oct 27, 2012
6,536
LED replacements for regular light bulbs seem to be taking a long time to catch up. I keep looking around various stores and find the biggest equivalency hasn't broken the 60W barrier, and the prices seem to suggest they're not all that eager to sell any!
Another option is LED replacement tubes for strip lighting fittings - but I think you have to rip out the ballast and re-wire the fitting.
Roderick Young
Joined Feb 22, 2015
408
I see you're in the Netherlands? I don't know if the same lights are available near you, but at Costco (a US retailer), LED fixtures that replace standard fluorescent tube lights are readily available, and not too expensive, either. The lights are sufficiently bright that our two-car garage is lit by just 44 watts, total.
boatsman
Joined Jan 17, 2008
187
There is a very big electrical shop in Amsterdam, I don't remember whether it's near the Dam or near the flower market, but they will probably have what you are looking for.
ian field
Joined Oct 27, 2012
6,536
They probably have Lidl and Aldi, which I think are both German.
Aldi is some distance from me, so I don't see their offers much, but I've had a LED worklight from Lidl and they have done LED security floodlights in the past.
The problem is; these items aren't regular stock - they release a leaflet every week with the offers on the following Monday and Thursday. If you don't buy while they're in, you have to wait till it comes round again.
bertus
Joined Apr 5, 2008
23,005
In holland we also have large DIY shops like Hornbach, Gamma, Praxis, Karwei and Formido.
All of them have a collection of led lamps and armatures.
I have bought some TL-lookalike lights with leds at Hornbach.
nic14
Joined Jan 8, 2014
12
Hello All,
going trough all the replies and checking the various links provided, I have finally made my decision
Now I just need to pick between 2 sizes for which I wanted to ask your feedback.
Type one is 150CM long and 3400lm
https://www.lampdirect.nl/philips-coreline-wt120c-led-3400lm-840-150cm
Type two is 120CM long and 4000lm
https://www.lampdirect.nl/philips-coreline-wt120c-led-4000lm-840-120cm
Putting aside the Consume for a second, which one do you think will illuminate the garage more?
Many Thanks for all your valuable feedback, and I apologize if I went completely the opposite
way of what some suggested :)
Nic
strantor
Joined Oct 3, 2010
6,875
Hello All,
Nic
They are made by the same manufacturer and have identical color temp so I assume the one with the higher lumens rating (your "type 2") would be brighter.
