Motorcycle Rectifier Regulator ------- Only one rectifier getting hot [SOLVED]
abuhafss
Joined Aug 17, 2010
318
Hi
Referring to SgtWookie's design for Motorcycle Rectifier-Regulator (Post #5) at
http://forum.allaboutcircuits.com/threads/12v-ac-motorcycle-regulator.39419/
1) I would like to request SgtWookie to please explain the use of the inductor L1. That circuit simulates the exactly same without the inductor.
2) I simplified it as per attached. I got perfect regulated voltage 14.4V; the mosfet remained super cool however, only D3 got hot. Doubting the condition of D3, I replaced with a fresh one but same result. I would like to have some valuable comments, why it is getting hot and what should be done to control heat dissipation.
AlbertHall
Joined Jun 4, 2014
12,663
If one diode in a bridge is getting hot then it usually means the opposite diode has failed short. In this case, with D3 overheating, that would be D1. This assumes everything is wired as per diagram. The 1N5408 is rated for 3A which is OK for 2.5A output, but the MOSFET regulates the output by drawing extra current through the bridge so the diodes have to be able to cope with the maximum generator output.
Not SgtWookie, but the inductor is probably there to help smooth out the switching spikes to keep them out of the control circuit. That circuit uses the MOSFET as a switch - it is either fully on or fully off - that keeps the power in the MOSFET to a minimum. Your circuit uses the MOSFET in a linear fashion so the power dissipation will be higher.
abuhafss
Joined Aug 17, 2010
318
Thanks for the input, AlbertHall.
After replacing D1, I shall get back to you on Monday.
Regarding mosfet, frankly I was also expecting the heat dissipation but, it is super cool!
Alec_t
Joined Sep 17, 2013
15,171
I suspect the anode of D3 should not be grounded in the real world (only in the Spice simulation).
Edit: Ignore. I was squinting at a small screen and misread the schematic :oops:.
abuhafss
Joined Aug 17, 2010
318
If not then D3 would be of no use and the bridge would be incomplete, ultimately the rectification would be half-wave instead of full-wave.
abuhafss
Joined Aug 17, 2010
318
The problem is when this is wired to the bike?
Then check that neither generator wire is shorted to chassis.
I tested the circuit on two other bikes and got the same result.
D3 ===> Extremely Hot
D1 ===> Fairly Warm
Mosfet ===> Cool
Regulated Output ===> 14.4 - 14.6V
AlbertHall
Joined Jun 4, 2014
12,663
Did the original circuit use a bridge rectifier? If not, one end of the winding may be grounded and that would account for the hot diode.
With the board disconnected check across each of the four diodes for a short and also check that the generator winding has no connection to the bike chassis.
Then, just to make me happy, remove the diagonal link which has one end between D1 and D2. It doesn't (or at least shouldn't) connect anything and it it worries me.
abuhafss
Joined Aug 17, 2010
318
Which original circuit are you talking about? I'd referred to Sgt.Wookie's circuit which had 4 diodes.
I had already checked each diode for shortage, all are fine.
The generator winding has no connection to the bike chassis.
The diagonal link which you are referring was actually used to provide a convenient connection to the harness connector when it was soldered directly to the veroboard. Later I removed the connector and reattached via wires so the diagonal link is confusing you, though I had clearly indicated that the link is separated from the negative rail................2nd picture, 4th track from the bottom. But still, as you said, I should make you happy. :)
The circuit's behavior is the same with that link removed.
Alec_t
Joined Sep 17, 2013
15,171
Can you tell us the exact make/model of your bike's generator?
Have you checked with a meter, when the generator coil is in place, that there is no leakage current through the bike chassis (e.g. due to insulation damage)?
