Motor Identification?
adamparker20
Joined Oct 10, 2021
I am hoping that someone can help me decipher what this motor is as I need to find replacement ones but would like to find the cheapest ones available (and I do not need any of the housing or components, just the motor).
The motor comes from a Bissell Little Green Proheat Clean Machine (same motor in all little green machines I believe). It is for the pump that pushes the freshwater and solution mix, however it ends up getting wet, rusting and unable to spin after a while. It is bissell part # 6035029. The motor has the following written on it from what I can zoom in on (some are a little suspect) and it has 3 wires that connect to it:
GEE GCR338WM-
27092AAEA3
MRD110Z31-1
E233520 26V
Thanks in advance,
Adam
MaxHeadRoom
Joined Jul 18, 2013
30,784
Well you know the voltage, just need the approx rpm, and shaft size, there are many DC motors out there of that size.
Either that or source a complete pump. unit.
