MisterBill2
- Joined Jan 23, 2018
- 27,880
Failure when mounted sounds a lot like a broken trace on the PCB or inside a part. Once I traced a failure to a diode with one lead loose inside the plastic.
So now it is time to grab a strong magnifier and a bright light and figure what area gets flexed when the board is mounted. AND still, it may be a failed solder connection.
