MaxHeadRoom
- Joined Jul 18, 2013
- 30,784
It might be an idea to do a little reverse-engineering around the 18pin IC, and draw the circuit up.
I'm not sure which semi you're referring to, but the item at the very top of the image, next to "SIEG" is labeled as U2, has four pins, and marked "V613Y 817C" (optocoupler). The item connected to a heatsink to the right of the transformer is labeled as U1, also has four pins, and marked as "5L0380R" (Fairchild Power Switch).Strange generator for PWM, I assume the large 3pin semi is the Mosfet or driver to the output,? But how is reversal achieved if there is only one?
The three legged TO-220 device.I'm not sure which semi you're referring to, but the item at the very top of the image,
The only TO-220 device is what I mentioned above as U1. And, no, this controller does forward and reverse. A one-way milling machine power feed wouldn't be much use.The three legged TO-220 device.
Is this just uni-directional control?
The important diagnostics for this problem can be done with a voltmeter, a scope is not required. The waveform when not operating correctly was similar to when it was working right, and so that part is not the problem. And the switcher power supply was functioning, just not supplying enough voltage. That was also apparently, also affecting the PWM frequency,it appears. So at this point a schematic and a voltmeter are the tools required.I'll add this, for anyone reading this thread and wanting to troubleshoot their similar motor controller...
The only signal I could safely probe with the oscilloscope was the output to the motor, since those pins are floating and not referenced to anything. The power supply in this controller is NOT isolated from mains with a transformer. Connecting the scope ground anywhere else in the circuit is likely to create a short and damage the controller or your expensive scope.
I did not see any devices that would be capable of the FWD/REV control?The only TO-220 device is what I mentioned above as U1. And, no, this controller does forward and reverse. A one-way milling machine power feed wouldn't be much use.
I wish I knew. I wish I had a schematic! Now that it's working again I have little incentive to reverse engineer it. Out of curiosity I'll check the LM324 pin voltages in FWD and in REV.I did not see any devices that would be capable of the FWD/REV control?
That is why I alluded to the TO-220 device.
For FWD/REV there is normally 4 switching devices and the LM324 would not be capable of providing the motor current?
Max, look at the picture of the control panel in post #1. There is a 3 position toggle switch to select direction. In a mill that would never be done automaticly.I did not see any devices that would be capable of the FWD/REV control?
Yes, I had re-looked and noticed it.Max, ook at the picture of the control panel in post #1. There is a 3 position toggle switch to select direction. In a mill that would never be done automaticly.
