I checked TPS51225C ic and I found that the pin 3 (VREG3) is short to ground. But I can't fine any short capacitor or mosfetDo your best to figure out what that IC powers, then start going through looking for shorts or possible failed parts. Try to find a schematic if you can, that will help a ton.
Try to find a schematic for that board, that will help you a ton. I don't know exactly where to look, but it seems repair places like Louis Rossmanns shop (youtube channel) seem to find them somewhere. Without that, just do your best to trace it around. Maybe it's a short diode or similar, lots of possibilities.I checked TPS51225C ic and I found that the pin 3 (VREG3) is short to ground. But I can't fine any short capacitor or mosfet
