AlbertHall
- Joined Jun 4, 2014
- 12,652
I guess that is going to 0V via the forward biased base collector junction.Something's certainly odd. There's 200mA base current!
This might be of use.Dana,
Could you elaborate briefly on that with a simple schematic?
Curious / interested.
I changed it to pnp....But still mosfets are getting shorted. very quietly. the supply 24 V goes to 20 the 16 ,..9 and then 0V heating up the smps.Your gate drive circuit has 2 NPN transistors - one with it's collector grounded?
This configuration is incorrect, It can never drive the gate LOW.
I too changed it to pnp, but the circuits not working still. what do you mean when you say top mosfet has no dc path for gate? which software are you using for simulation...I changed the sim to use a 2N3906 (PNP) for the bottom transistor and it works much better.
I don't like the fact that the top MOSFET has no DC path for the gate. It works OK in the sim but would probably not in a real circuit.
Thank you for your input.I would start by looking at gate drive with a scope, replace MOSFETs with
equivalent gate C, sure looks like you experiencing either excessive Vgs or
Vgd or Id due to overlap eg. both top and bottom mosfets shorting supply
rail.
You could do a single pulse (leaving MOSFETs in place) and set scope up for
single shot trigger.
https://hackaday.io/project/3176-gator-quad/log/11741-pwm-control-and-dead-time-insertion
Regards, Dana.
Scope should have a sweep mode single shot. You set Vtrigger for some value you areThank you for your input.
I too feel the same. But if overlap is the problem, then it should not work on no load either.
How can I obtain a single shot trigger?
Thank youScope should have a sweep mode single shot. You set Vtrigger for some value you are
looking for , like its max Vds spec value, and see if it gives you a trigger. Or you can take the
trigger out signal on scope, and use that to trigger the gate drive signal by pressing the run/stop
button on scope. So hitting the R/S button scope generates a sweep and a leading edge trigger
and you see a single sweep event, usually if there is a fault you can keep from blowing fets doing
it this way. Its tricky.
Regards, Dana.
LTspice. Freeware from Analog Devices.Can you tell me which software is suitable for simulation of power circuits?
thank youLTspice. Freeware from Analog Devices.
Sir, I'm Posting the circuit again... The circuit works well on no load but moment i connect the load one PNP mosfet gets hot and trips the supply. Is there something wrong with the configuration?I did a simulation of this, using 2N3904, but the emitter of the lower transistor doesn't get above 43mV despite 84mA flowing in the 51Ω resistor. I think this must be that the model doesn't understand 2N3904 with reverse polarity?
Repeating the description of your problem is not going to help.
I would open doc any day. Use pdf.
Sir,I too changed it to pnp, but the circuits not working still. what do you mean when you say top mosfet has no dc path for gate? which software are you using for simulation...
Sir, What will??Repeating the description of your problem is not going to help.
Input voltage is 5V, square wave pwm, 100khz, mosfets have 24VI too changed it to pnp, but the circuits not working still. what do you mean when you say top mosfet has no dc path for gate? which software are you using for simulation...
Thank you so much for your reply....Should I change the zener to 18VIn your circuit, if D3 is a 15V zener then the voltage at Q6 gate is always 15V above Q3 emitter, i.e never rises above about 19V. That means Q6 is permanently on (unless its Vgs turn-on threshold is unusually high).
Or should I eliminate it completelyThank you so much for your reply....Should I change the zener to 18V
Sir,Q3 emitter voltage can only change by about 4V. Re-consider how you will use that to switch Q6 on and off reliably and whether a more conventional gate driving arrangement would be better.
