DPDT/H-bridge switch for 24V 4A max load by use of Mosfets,
abdulbadii
Joined Aug 30, 2017
90
How is the correct DPDT or H-bridge switch for 24V 4A max load DC motor by use of Mosfets, how is correction of below ?
enter image description here
Please give useful explanative solution
Sensacell
Joined Jun 19, 2012
3,787
There is no gate drive in this circuit, the gates will be floating, at an indeterminate voltage.
If you have a DPDT switch, you don't need any transistors to reverse the motor.
Audioguru again
Joined Oct 21, 2019
6,826
Even if you switched suitable gate voltages to the Mosfets to turn them on or turn off, during the switching an upper Mosfet and a lower Mosfet will both be turned on for a moment, shorting the power supply and getting very hot, called "shoot-through current". Therefore a delay must be added so that one Mosfet turns off before the other Mosfet turns on.
