nepdeep,
OK, let me try to clarify.
First of all, we don't need to keep stating the condition Vgs > Vth. This simply tells us that the mosfet is turned ON, and the ON condition is all we are discussing. So, for our discussion, its a given that the mosfet is turned on by a voltage at its gate greater than the threshold ...
Case 1 (Saturation):
MOSFET is saturated. This means it is turned on as hard as it can go and is no longer operating in a linear region. The resistance of the mosfet is RDSon. This is how mosfets operate when used as switches in circuits like switching power supplies and motor controllers.
In saturation, the voltage drop across the mosfet is simply Vds = Id x RDSon.
Looking at a mosfet datasheet, the relevant curve for the saturation mode is the Vgs vs RDSon curve. This shows that a large Vgs such as 10V-12V (which is how you saturate most mosfets) gives you a very low RDSon (in really good mosfets this could be 10 milliohms or less)
Case 2 (Linear operation):
MOSFET operating in its linear region. This means its turned on partially and basically acts as a variable resistor, with the resistance controlled by the gate voltage.
In the linear region the voltage drop across the mosfet Vds is a function of the gate voltage Vgs, and the drain current Id.
If you look at the mosfet curves, the Vds vs Id curve is the relevant one in the linear region. You will be driving the gate at a voltage Vgs which is only a little above the turn-on threshold Vgs(th).
Confusion factor:
Here is where the confusion comes in ...
My descriptions above are of the terminology commonly used by designers who use mosfets. We generally think of mosfet saturation as the case where the gate is driven very high (such as 10-12V) and the mosfet is fully on, and the on resistance is RDS(on), generally very low, maybe milli ohms.
But really, the proper use of the term saturation just means that you are operating the mosfet in a region of the Vds vs Id curve where increasing VDS will not get you any more drain current (i.e. the flat part, or top, of the curve). In this case, if you want more drain current, you need to increase Vgs.
Its really not that hard to understand from a practical standpoint.
Saturation is when you turn on the mosfet fully by driving its gate to 10-12V (varies depending on the mosfet, so-called logic level mosfets saturate at lower gate voltages)
Linear operation is when you drive the gate at a lower voltage and the mosfet acts as a variable resistor. In this mode, you need to concern yourself with the mosfet curves.
Hope this helps.
Confusion factor:
Hope this helps.
