MOSFET Switching Loss Formula
hoyyoth
Joined Mar 21, 2020
531
Dear Team,
I was learning about power MOSFET losses(Switching Loss).I found two equations for calculating the switching loss parameter.
May I know which one is correct or are they the same.
The first one I obtained from TI(please see the hyperlink below) and the second from power electronics news( please see the hyperlink)
From TI Material
From Power ElectronicNews
Regards
HARI
LowQCab
Joined Nov 6, 2012
5,102
Neither one will give You an accurate, "Real-World", result.
they are theoretical formulas that are meant to give You some "idea" of what You "might" expect.
And then, there's what really happens after You build it.
There are "simulation" Software-Programs that will do the same thing.
