I want to measure the resistance of my load R4 that varies between 0.10 to 3.00 ohm.
I made a voltage divider R2, (R3+R4) and want to read the voltage with my ADC of my Arduino.
I use PWM at 100hz, and switch off U1 and switch on U2 & U3 during 200 microseconds each cycle.
XMM1 is my ADC connection, Source of U3 is connected directly to my ADC.
I'm not sure if you could do that, guess the source is not correctly grounded then?
But I don't know how to switch off the ADC connection when not measuring.
This circuit seems not to work since U2 always get blown.
I would appreciate any help to solve this.
Guess it may work with a P-channel MOSFET instead?
Is there any better way to measure the resistance of R4?
Thanks
/Anders
Thanks
/Anders
