Mosfet switching circuit
rashmihm
Joined Sep 20, 2017
12
i am trying MOSFET switching circuit to switch milivolts voltage to volts but when i increase drain voltage resistor and MOSFET are heating what wold be the solution...
rashmihm
Joined Sep 20, 2017
12
I am getting millivolts but to drive transducer i need 3v to 5v Peak to Peak voltage.am using MOSFET switching circuit as shown in attachment.
ScottWang
Joined Aug 23, 2012
7,504
If the input signal only has 750mV then you should use a npn transistor to amplify the signal and the output to drive the P type MOSFET, and if the output only needs 3~5Vpp then you will need a voltage divider.
How much current you need from the output of MOSFET?
Do you have more info about the transducer?
Picbuster
Joined Dec 2, 2013
1,059
Look at the gate voltage needed to switch the fet on.
My grey mass indicate 2 or 4 Volt but could be wrong.
Note: obsolete part the eol was years ago.
Picbuster
rashmihm
Joined Sep 20, 2017
12
1)I want to drive 1Mhz transducer, current has not been specified in data sheet but transmitter burst pulse should have 3Vp-p to 5Vp-p.
2)when i provide 20v dc supply to the drain of MOSFET as shown in above circuit am getting output square wave of 2Vp-p but resister and transistor gets heated up.
3)am not getting more then 750mv because am getting this voltage from TX pin of TDC-1000 chip.
bertus
Joined Apr 5, 2008
22,967
The mosfet will be biased by the voltage from the potmeter.
The mosfet will be and stay in linear mode, so there will be heat generated.
Bertus
rashmihm
Joined Sep 20, 2017
12
If the duty cycle of input signal is to narrow then it should be reduces the values of R2 and R3, the Imax ≅ 20mA, if you use the N MOSFET on the output then probably you can't get a 0V to 5V level signal.
Why you need to using 20V to be the power source, why not 12V or 5V?
Hi scott,
i tried with 5V and 12V for MOSFET circuit but it din't work out so i tried for 20v. Thanks for the circuit suggestion i will try out this and let u know the result.
ScottWang
Joined Aug 23, 2012
7,504
Hi scott,
If you using the circuit that your posted in the first post, the output voltage is quite high when the input is 0V then the output will be close to 20Vdc, for 12V is easy to make the MOSFET to turn on, but when you use 5V for the power source then you better to choose the type of Vgs has logic level = 4.5V or 5V.
rashmihm
Joined Sep 20, 2017
12
Hi scott,
i tried the circuit without mosfet part that has attached but am not getting any wave form.
1)Is it k if i use BC557 pnp transistor in place of 2n3906 pnp transistor
ScottWang
Joined Aug 23, 2012
7,504
Hi scott,
Try to measure the c of Q1, if it still no any waveform then the problem could be R1(reduces it) or the input voltage too less to active the Vbe as the same that the Ib1 is too small.
rashmihm
Joined Sep 20, 2017
12
I measured the voltage across collector of Q1,i got waveform but voltage has dropped am getting 58mv across the collector of Q1
rashmihm
Joined Sep 20, 2017
12
I measured the voltage across collector of Q1 am getting waveform with 58mv there is a huge voltage drop after the transistor Q1 and across Q2 am not getting any waveform.
