I just purchased this MOSFET:
https://assets.nexperia.com/documents/data-sheet/PSMN017-30PL.pdf
and I am using it in conjunction with a microcontroller as a low side driver. The microcontroller outputs 488Hz pwm at 3.3V logic level. The input voltage to the mosfet is 24V and the output current is about ~1.2-1.3A. I am calculating temperature rise according the to the information in the data sheet choosing the least favorable numbers.
Power consumption: Rd-on * I^2 = 0.04536W
delta T = P*Rth = 2.72K
according to this the temperature of the MOSFET should only rise by about 2.72 degrees. I tried running the mosfet by connecting constant 3.3V to the gate so that I can ignore heating from switching. What I found was that the MOSFET heats up by a lot in a very short period of time. What am I missing?
