TIP122? Or a T092....
TIP122 is a Darlington in a TO220 package. A TO-92 is a plastic through hole package. I don't think you want to go there. If using a through hole part it should be in a metal can (TO-18 maybe). If using a surface mount part it should be a DPAK or a SOT-89.TIP122? Or a T092....
Is this the circuit that you have in mind?Link is: https://www.homemade-circuits.com/mini-50-watt-mosfet-inverter-circuit/
I want to replace all the other additions with a gate driver using amplifier.
Yep. That's it.
