Mosfet driver
Alec_t
Joined Sep 17, 2013
15,119
The gate lead resistor serves two purposes. 1) it supresses undesired oscillation, and 2) it limits the inrush current when the gate driver supplies current to the gate capacitance to charge it.
shortbus
Joined Sep 30, 2009
10,050
Like Alec said the purpose is to stop ringing and oscillation. But using to big of one also slows down the charging of the gate/source capacitance and slows turn on of the mosfet. It's also a good idea to put a resistor in the k ohm range between gate and source to keep the mosfet gate pulled down and turned off when its supposed to be off.
tracecom
Joined Apr 16, 2010
3,944
I use a pull-down resistor on the gate; I have seen a variety of values used from 1k to 100k, but don't really know what is optimum.
Is the ringing/oscillation you describe caused by the MOSFET or by the driver, and if it is the latter, is the resistor still required with the driver is a uC?
GopherT
Joined Nov 23, 2012
8,009
The only purpose of the pull down resistor is to make sure the gate doesn't float to dangerously high static levels if the driver is switched to a high impedence state or physically unplugged from the mosfet or a switch disconnects the gate from the circuit. There are some other switching mechanisms with diodes to the gate that allow a path to ground and must be smaller value resistors to speed turn-off speeds but, if diodes (or single transistor switching is not used, then fairly high resistor values can be used (100k).
A gate resistor also can be used to slow the mosfet switching speed to control (reduce) EMI for high current or mains-connected devices.
