Mosfet driver burning, see schematic
KeithWalker
Joined Jul 10, 2017
3,628
The labels on your diagram diagram are a little difficult to read but both of the MOSFETs on the right appear to be switched on by the same signal; "C:ll l". That would create a direct short across the supply.
sarahMCML
Joined May 11, 2019
707
Why have you got 10nF capacitors each way across the outputs? They're just extra current that's got to be charged and discharged every cycle for no gain, to the detriment of the 'FET's.
KeithWalker
Joined Jul 10, 2017
3,628
The schematic diagram is only half of the story. We have no idea what the software is doing and we have no information on the motor. That makes it very difficult to guess at what could be going wrong.
Has this worked correctly and just failed, or did it never work properly.
Based on the information supplied, my best suggestion is that it is broken!
