panic mode
- Joined Oct 10, 2011
- 5,299
Fully aware/Didn't followin other words you are not aware of or have not followed ESD guidelines?
hi,Using a device in the linear mode often leads to excess internal heating problems.
EFinally found it. Someone on reddit suggested that the gate resistor was too high regarding the esp32's pwm frequency (19.5kHz).
Measure the VGS with a multimeter. Also check for accidental short circuits. If you are using a multimeter, check that too. Sometimes these boards create problems.Hello everyone, recently i bought an rgb led strip and i tried to modify the controller to work with esp32. I desoldered everything from the premade controller except for the mosfets and the 2 resistors you see in the schematic. Mosftets are AO3402 (340s marking). After flashing the esp and connecting to gpio it blinks for few seconds and then it stays partially on. Shorting the gate to source doesn't turn it off. It's a 24v led strip and at first try i didnt have the grounds of powersupply - esp32 connected. I thought that was the problem but it happened on the second mosfet too. What could be wrong. On second try i also removed the 10k resistor.
Thanks in advance!
View attachment 334545 View attachment 334546
Seems you might have found the problem indeed.Facepalm time. Measured Vgs when on and its ~1.5V because i had the brightness set to 50% on the esp. What bothers me though is that i dont see a reason it would burn as the original controller could dim it 0-100%. When first testing it the mosfet was not even close to hot to the touch.
