Dave,
Ratch
I disagree. All devices obey the resistance formula V = IR at all times. Not all devices do it in a linear fashion to comply with Ohm's law. What in the world does the Ebers Moll transistor model have to do with this?This characteristic is embodied in the equation:
I = V/R
Now it is correct to say not all devices obey this law for their V-I characteristic, diode being an obvious example where the I-V characteristic (note the switch from V-I to I-V) is defined by the non-linear Ebers Moll relationship.
I can't quite figure out what you are saying. The derivative of a exponent is also an exponent. There might be a small region close to zero where a diode might be approximately linear. Within that range, it could be said that the diode is ohmic. But stray very far from zero and the diodes's nonlinearity becomes readily apparent. Anyway, the resistivity/conductivity of any semiconductor is well known to be nonlinear and nonohmic.There is an important point to note - even non-linear devices display Ohmic behaviour - consider the diode which has an exponential I-V characteristic, that is as the voltage across the diode changes (ΔV) so the current varies non-linearly in an exponential manner. If we take the condition that ΔV tends to 0, i.e. we are look at the I-V characteristic locally we see that device behaves Ohmically - that is the resistance at that point, R = V/I. This is the same as saying the resistance is the reciprocal of the derivative of Ebers Moll defined at a voltage V where ΔV is zero. Therefore locally, diodes like all electronic devices, obey Ohms Law.
Ratch
