Monostable 555 Trigger release issues
d4d0m3n
Joined Sep 24, 2023
30
Hi. I am referring to this thread: https://forum.allaboutcircuits.com/threads/monostable-555-trigger-release-issues.113131/
Particularity to post by @crutschow :
In my case, output will not time out. Maybe the reason is because I have a 1uF cap & 300kO resistor, instead of 22uF & 47k, so the pulse windows is too short? I am using the same diode 1N4148, TLC555 (cmos) timer, SW-520D ball switch, and output is going to a mosfet. What could be the reason and what are the possible alternatives?
d4d0m3n
Joined Sep 24, 2023
30
Then I expect a wiring error (or less likely, a faulty component).
I see. So it has to be polarized. So even if I use following setup, the short pulse width actually doesn't matter? It must only change ceramic cap for a electrolytic one?
38,814
You said the charging capacitor was 1uF but the schematic shows 470nF.
Which is correct?
Can you measure the voltage at pin 2 using a multimeter with the button continually pressed?
eetech00
Joined Jun 8, 2013
4,724
No. It doesn't have to be polarized.
Try connecting a 10nf cap from pin 5 to ground.
Also connect 100nf cap across supply pins.
d4d0m3n
Joined Sep 24, 2023
30
Which is correct?
1uF, but I am planning to use 470nF later.
Voltage is fluctuating from 1.2 to 2.4V
I now found the cause. Motor vibrations are disturbing the ball-switch, causing re-triggering. Is there a way to soften it?
d4d0m3n
Joined Sep 24, 2023
30
To put another capacitor in parallel with a ball-switch will probably not be enough to eliminate the noise? Or? If, what capacitor would you suggest and if it has to be combined with resistor? Thank You
d4d0m3n
Joined Sep 24, 2023
30
Add reference designators (R1,R2,C1, etc.) to all components so we can communicate changes easier.
470n, 100n, 10n are non-polar.
The 2k resistor in series with 470n is not needed.
Not all TLC555 can be used with supply of 3v.
What is the suffix for the TLC555 part number you are using. It should TLC555I.
Done. C1 as a timer cap is supposed to be polarized, isn't it?
