Modifying electric fence circuit
Yardy
Joined Mar 26, 2019
17
Hello good day to everyone here - I am trying to build a solar powered fence charger to keep out animals and humans -
I have attached an image of a cdi ignition module based fence charger but it works with mains voltage - I would like to use a solar
panel to power the circuit but without batteries as its only going to be used during the day - A cdi module wont be hard to source
out here in jamaica so i was wondering if anyone could tell me what to change on the circuit considering the input will be 12Volts.
28,626
That circuit is not a "fence charger"by any stretch! It is a mains powered shocking circuit. It is also much more complex than any electric fence charger that I have seen.
28,626
Thanks to "C" for providing an actual fence charger pulse circuit that was clearly laid out and easy to follow. It may still require an actual battery, or a super-capacitor, to supply the pulse current, which will not be small.
A power transistor, Q2, driving a power transistor, Q3 is a bit unusual but it makes perfect sense in this circuit.
I wonder about the source of that circuit we see in post #1, as it is quite complex for the function it is claimed to provide.
28,626
OK, a 5 mF capacitor with zero internal resistance may be a challenge to find, but for the low voltage that the circuit uses, and considering that size is probably not a big issue in this project, even a 470Mfd capacitor should fit very well.
An interesting variation would be to replace the timer trigger with a capacitor voltage sensing trigger, so that on a sunny day the pulses could be much more frequent, while on an overcast day the pulses would be less frequent, but still the same amplitude. Since the 555 timer uses a comparator to trigger the time cycle ,that should only require a minor circuit adjustment.
Yardy
Joined Mar 26, 2019
17
crutschow i thought of using a tv flyback to power this as i already obtained one - i have not been able to obtain an ignition coil out here as when i ask they dont know what im talking about
38,952
No, a tv flyback transformer will not likely work well.
Use one like this:
You should be able to find one in an automobile junk yard, if there's one near you.
Reloadron
Joined Jan 15, 2015
7,980
Just as a side note and something you want to consider. Solar panels are rated using their maximum output as in bright sun directly overhead. On an overcast day good luck. Thus you want a battery. You can work it so the fence is only powered during daylight hours.
Ron
28,626
Parts availability varies in different parts of the world. Also the technical knowledge and abilities of those folks representing that they have the ability to diagnose and repair things. And that lack of insight certainly extends to those merchants selling stuff.
