model house project
sailingboarder
Joined Jan 25, 2008
12
so our project that is going to be assigned in the few weeks and will be due late may has some fun tasks, but i'm looking for some ideas to make it over the top
we have to build a model house(24" by 36" i believe) and wire it with a few light bulbs, a doorbell, and switches, and such...all basic stuff
we also have to use a motor in any way we want(like open a garage door, run an elevator, etc)
i'm interested in some unique ways to use a motor in a model house, or anything else you would wire into a model house if you could
our last project was really over the top making a machine, that i want this one to be equal or better
beenthere
Joined Apr 20, 2004
15,819
How about an escalator in place of stairs? Or a passive solar house that turns on a pedestal to follow the sun (a light source) for maximum insolation? Have bump-out guest rooms?
thingmaker3
Joined May 16, 2005
5,083
Scale model ceiling fan? Functioning air-conditioner or heater? Sump pump?
As far as "anything else," what about burglar alarm, surround-sound home-theater, and/or LAN & phones?
sailingboarder
Joined Jan 25, 2008
12
haunted house feel would be pretty cool though,
all those ideas sound really sweet, i guess the only limit for our group will be time and maybe money
i was thinking about solar panels to run the house, so revolving to follow the light source would be cool(though i've never heard of a real house doing that)
beenthere
Joined Apr 20, 2004
15,819
One guy that made a passive solar home had the whole south wall hinged at the bottom. He could lower it down to reflect in the maximum amount of light. I think it was Amory Lovins.
mrmeval
Joined Jun 30, 2006
833
Peltier chip could provide AC. Heat provided by the same Peltier chip. You'd want a ventilation system and proof it's working with some temperature sensors. Couple this with some sort of solar system. I just say a 'let it droop' style polished sheet metal one that allows the metal to sag to what ever depth it will with gravity then you stick a collector at the focal point.
Lazy susan to make a turntable house, yes it exists. You'll need a motor control with position sensor and maybe a sun tracker.
All the 'lamps' should be LEDs and with PWM brightness control.
Every scrap of electronics run by some sort of renewable energy, have a storage system and also be able to connect to the 'grid' aka wall wart at need.
Independent control of the LEDs so that you can flash them to a funky beat. ;)
Octavian01
Joined Mar 1, 2008
6
for the motor idea, i was thinking you could build some mini blinds, out of strips of paper, or even strips of laminated paper, and string them together with some sewing thread, then use a servo, or small motor wired to a switch on the wall that lets you automatically open the blinds in the rooms. That would be cool kinda like the house bill gates built
thingmaker3
Joined May 16, 2005
5,083
One of my friends helped wire the Gates residence. Visitors are issued RFID badges and are asked to fill out questionnaires regarding preferences of temperature, lighting, and music. The house adjusts environment in rooms accordingly.
How an RFID might be miniaturized to work in a model, I don't know. But it would be a cool project.
sailingboarder
Joined Jan 25, 2008
12
i like the blinds idea, if we can make it work on small scale
as far as saving power from a solar source, what is the best method, just chargeable batteries?
and is there a semi-easy/cheap way to centrally control all these different motors and switches, that we could then program or control remotely...this is not necessary, but it would be cool to put our house in a sort of demo mode before or after the presentation with the lights blinking and everything moving to a beat like mrmeval suggested
