microwave - resuscitation - desperately looking for an advice
35,170
A switch with 2 pins is a SPST switch (single pole single throw). You test for open and closed contacts.
A 3-pin switch is SPDT switch (single pole double throw). The terminals are labelled NO-COM-NC (normally open - common - normally closed).
You test for continuity from COM to NO or NC depending on the state of the switch.
LesJones
Joined Jan 8, 2017
4,543
The micro switches with 3 pins will have changover contacts. This means that in the non actuated position one pin (The common) will have continuity with one of the other two pins, (That pin is the normaly closed pin (NC)). The remaining pin will not show continuity to either the common pin or the NC pin when the switch is not actuated. This pin is called the normally open pin.(NO).
When the switch is actuated there should be continuity between this pin and the common pin. In the actuated state there should be NO continuity between the the common pin and the and the NC pin.
Les.
35,170
I have not read what are the symptoms for “partially working”.
Control panel lights up and functional?
Microwave goes through proper operational cycle?
Not able to make.warm water?
LesJones
Joined Jan 8, 2017
4,543
What was the temperature of the water at the start of the cycle ?
How much current is the microwave taking from the mains supply during the heating cycle and what is the mains voltage in your country ?
Les.
thor21
Joined Sep 29, 2024
435
just odd question ... why is that magnetron such an expensive? I mean one can buy brand new microwave for 100e and that magnetron costs 200 euro+
also the is magnetron Toshiba 2M282H(L) which seems to be discontinued
someone advised its replacement is part listed on ASWO pn: #H626103
as i dont have access to AWS i am not able to find the brand/ mode.
Is it possible to help? thanks!
wayneh
Joined Sep 9, 2010
18,162
You're finding what I have found in the past, that you may as well buy a new microwave if your magnetron is shot. The manufacturers have no incentive to enable inexpensive DIY repairs. If you make magnetrons, you want to sell them by the thousands, a pallet at time, to whoever is assembling microwaves. You can make money shipping them one at a time but that's a very different business and you need a much higher margin to cover the overhead.
Externet
Joined Nov 29, 2005
2,676
A magnetron is not expensive. The guys selling them are squeezing any wallet that can find to the maximum for you to pay their mortgage in a day.. I would put some neon bulbs or compact discs or aluminium foil confetti/strips, grapes, steel wool scrubber, on a stand-off like an inverted cup and check if there is emission of microwaves, sparks will tell yes.
Recently transplanted some guts of a free $0 microwave oven into mine, full success, now working daily better than when new. Many are found in dumpsters with perfectly canibalizable parts. Post #366 at :
----> https://forum.allaboutcircuits.com/threads/what-did-you-repair-today.194969/page-19#post-1984061
