Gee Don,Hey Sarge,
Almost there! I can almost taste it I'm so close. However I need your help and advise.
The motor I was using was just to long to work, so I fashioned a gear head from one of the old turret rotation motors.
However when I went to put her all back together I kindaforgot how to wire the remote into the circuit. The remote reciever has a + - Comm NO and NC
I know the connection for the RX-18 goes to the COMM, but that is where I am lost again. If you could show me a basic sketch of how to wire it to the remote that would be a great help. I get confused on where the power comes in. From the Remote or from the board.
And just to clear up something in my own mind. On the board does Ground mean NEG?
Once again Wookie you are tops and i sure thank you forall you have done!
Don
Good deal! Glad you figured it out.Hey Sarge I figured it out and got it going. When I Xfered the traces to the board for etching the trace for the motor negative did not Xfer in just a tiny little area. I found the Open when I was using the meter to check voltage. I put in a small jumper so as not to damage other traces and now it is working.
I think this has been covered before. However, the pad marked RX-18 needs to get connected to the battery positive terminal (via a fuse, of course) momentarily in order to start the sequence.All that remains is your guidance in hooking it to the remote control.
