How to locate information on an old Micro Switch ????
xtal_01
Joined May 1, 2016
227
So ... the neighbor has a manlift that died. He is an older farmer that I am trying to help out.
It stopped moving ... did some searching and found the foot switch in the basket was bad.
Pulled it apart ... it has two BA-2R62-A4 Mirco Switches in it ... one is bad.
So ... pulled up the cut sheets on Honeywell Micro Switch ... No 62 in any of their part number!
I called them to see what the 62 meant .... they looked and could not tell me!
They still make a BA-2R-A2 (and A4 ... this is just a #6 or #8 screw terminal).
They sent me a drawing of the BA-2R62-A4 and BA-2R-A4 ... both seem to be identical! I compared everything .. ratings .... sizes .... travel .....
The only difference I can see is an added note on the "62" saying "switch must withstand 2000 volt dielectric between common and normally open terminals" ... which really means nothing to me as the lift as a 12 volt system in it.
So is there any way of knowing what the 62 in the part number meant?
I just want to make sure I don't miss anything when I get a replacement switch.
Thanks!
MaxHeadRoom
Joined Jul 18, 2013
30,837
It's only rated for 2 amps; you should be able to fit almost any of the micro switches out there. There is no lever or operating mechanism evidently??
You can get all kinds on Amazon for cents
xtal_01
Joined May 1, 2016
227
Actually, it is rated for 20 amps. Yes, no lever ... just a small pin sticking up about an 1/8".
Super heavy duty casting foot pedal to enclose it.
MaxHeadRoom
Joined Jul 18, 2013
30,837
I very much doubt it! I have never come across a micro switch rated that high?
What is it directly operating? A relay ?
Here is what I found on it.
xtal_01
Joined May 1, 2016
227
I stand corrected!:oops:
It would be interesting, however, to know what the micro-switch controlled.
There are two of them in the foot switch (on the basket) of a JLG man lift. Looks like they are wired together to "flip" the polarity of two wire.
You can see this on page 3-25 of the manual (there is a full schematic there ... link below).
JLG 40HA manual
xtal_01
Joined May 1, 2016
227
So what device is finally being switched by the micro?
The wiring diagram is soooo bad, I am having problems reading the numbers and tracing wires.
My hint was, they were driving it and it stopped moving.
He stamped on the foot pedal a few time .. it moved a bit and stopped completely.
I took the pedal apart .. one switch i fine. The other has the pin just loose. No tension against it ... will go in and out when you turn the switch right side up and up side down. The one that works has a definite snap action to it.
Before I go too far, I will replace the switch and see what happens.
Just want to get the lift working for them. They are trying to get the roof on a barn before the snow flies.
