Micro Joysticks In Place Of Dial On Servo Testers
Ya’akov
Joined Jan 27, 2019
10,370
Will that power multiple ATTINY85s
That board will produce 1.5A without cooling, 3A with it. The ATTINY85 (and even the entire Digispark Pro) resquires on the order of hundreds of μA. so you could literally power thousands of them, in theory. In other words, “yes” but you recall that single point of failure was a concern, so you probably want some strategic redundancy.
DragonTheta
Joined Feb 6, 2022
89
I'll power them with a 4S lipo. This electronic speed controller that I plan to use doesn't show any 5 volt. It shows the battery voltage and the ground and another wire that says Curr. Perhaps that one could be the 5v
KeithWalker
Joined Jul 10, 2017
3,628
The spec sheet for the 50A BLHeli_S ESC states that is has a 5V BEC:
"Built-in 5V@2A BEC, which can be flight control.".
Why would you not use that to power the ATTINY circuit?
DragonTheta
Joined Feb 6, 2022
89
The one I bought before didn't have 5v so maybe the new ones do now. I'll find out when I get another.
There is a physical space requirement which may cause me to decide to run two motors off each user input device. Will I be able to duplicate the output signal from the ATTINY85 to send signal to two motor pads from one ATTINY85 or would I need to double the amount of ATTINY85s and duplicate the signal from each user input device
KeithWalker
Joined Jul 10, 2017
3,628
Do you want to control two motors with one joystick or have two joysticks to control two motors independently with one ATTINY85?
Either way, it can be done.
DragonTheta
Joined Feb 6, 2022
89
What is the thing that comes with the DigiSpark that looks like nine metal pins connected by plastic
Where on the DigiSpark will I connect the micro joystick, and where will I connect the output to the ESC
KeithWalker
Joined Jul 10, 2017
3,628
The pins on the plastic separator can be soldered into the holes around the edge of the Digispark if you want to use it in a socket.
If you use the program I posted in answer #42, this is how you would connect them:
DragonTheta
Joined Feb 6, 2022
89
Much appreciated
I only see 5v, gnd, vin, R0, and P1 through P5 on the DigiSpark. I don't see D0 and A1 like in the diagram.
