Thank youStart at the Alpha-Stim website. They have a bibliography there.
Thanks for this project. I would love to build it, but, frankly I have no idea which version is which. I find two schematics & two wiring diagrams, of which none of them seem to correspond with any of the others. Do you have a final schematic & wiring diagram which are the correct ones to use? I have chronic (spine related) pain & fibromyalgia, and hope to use this device for relief from symptoms! Thanks again!Thank you
Start at the Alpha-Stim website. They have a bibliography there.[/QUOTE
Are you asking about the schematics for my project? The information is in my first post, with a correction to the PCB layout in post #28.Thanks for this project. I would love to build it, but, frankly I have no idea which version is which. I find two schematics & two wiring diagrams, of which none of them seem to correspond with any of the others. Do you have a final schematic & wiring diagram which are the correct ones to use? I have chronic (spine related) pain & fibromyalgia, and hope to use this device for relief from symptoms! Thanks again!
My wife and her friend tried one of the expensive devices at a trade show and came home with glowing reviews of the experience. My wife's friend in particular felt an enormous reduction in anxiety.By the way, how it is about safety of using the brain like a current filled wire??
I used these clips on these wires. I also found cheaper ones. I got some conductive gel but I don't think the users bother with it. It seems to do the job without it.Wayneh:
May I ask to explain what kind of electrodes You use to earlobes. Metal type, size, wetting system (concentration of salts and what salts), fabrics wrapped around, precise touching placement etc etc details.
The boards I used are like these. Very cheap.By the way, why You arent using the PCB software like FreePCB or SprintLayout what are so easy to use. To push the aerosol is fast and accurate too, I mean Positiv-20. Thus the PCB will have a tenfold less a time for mounting, and at least my local store wants for Your style board the price equal to 100 pieces of DIY made `real` pcb. Actually never had understood why they being a mass product are so unpardonable pricy, the 4...6 Eur for just 2x3 inch piece, if A4 sized two-side pcb costs about 3 Eur.
Correct, I use it because there was no learning curve for me - I have a long history using vector drawing apps since they first appeared. A few here use paint programs for the same reason. I can't fathom that! But a tool you know is hard to give up for one you do not.Nice project! I'd be interested in using the "Intaglio" software but I did a google search and nothing turned up? Can you point me to where I can find/download it?
EDIT:
Just noticed that this was a vector graphics program not something bespoke for prototype PCB's. Never mind![]()
I still use vector graphic programs for designing 2D net enclosures, and I enjoy using Inkscape for general graphic design.Correct, I use it because there was no learning curve for me - I have a long history using vector drawing apps since they first appeared. A few here use paint programs for the same reason. I can't fathom that! But a tool you know is hard to give up for one you do not.
I don't see any reason you couldn't achieve this. You could use a potentiometer to get all these values, or a switch and fixed resistors to select pre-defined values.This is interesting, I am just beginning my learning journey here but would be interested to know how difficult it would be to be able to select from 3 frequencies like 200hz, .6hz or .3hz
Did you mean to post this here, or over in the "random noise below 30Hz) thread?The linked circuit with two 555 ICs, a 4017 IC and two opamps produce random digital pulses, not random noise. Also its frequency range is only 4 to 1.
The analog circuits making real random noise from a reverse-biased transistor emitter-base or a Zener diode are designed to be powered from 18V that drops to 12V during the life of the 9V batteries.
It is easy to change the cutoff frequency of an 8th-order switched capacitor Butterworth lowpass filter IC.
