dheena0104
- Joined Jul 10, 2019
- 36
Dear Mr Wayneh Ji
Greetings.
I hope that I have done some thing finally and trying to disturb you to correct it as a meaningful thing for the real world application.
Assumptions
1. Random period and polarization are not necessary.
2. Body resistance: 10 K ohm to 150 k ohm (no conducting gel, only conducing pad or electrode)
3. Schematic with 555 (timer) and JFET (12SK170X) as attached.
4. Power supply for 555 IC 9 V and for JFET 15 V (not specific).
5. R3 load resistance varied 1 K Ohm to 200 K Ohm
Simulation
At 10 K load V=1.8 V and I= 180 uA
At 200 K load V=11 V and I= 55 uA
Even at 1 K Ohm load V=0.85 V and I= 850 uA
If this circuit works (your confirmation needed), then the values are at the safe level irrespective of low voltage at low load resistance say below 50 K Ohm (V=6 V and I = 120 uA).
Problems faced: Proper biasing of 12SK170X , when tried to increase the voltage below 50 K Ohm load, hence tried to keep R2 as low as possible in order to pull down the gate voltage.
Finally, through this update I tried to confuse you as little as possible please
Greetings.
Assumptions
Simulation
