MIC557 circuit frequency output issue
Gibson486
Joined Jul 20, 2012
360
I made a circuit attached, however, the frequency keeps shifting back and forth by approx +/-10kHz. In other words, it hits my frequency of around 260Khz, but the frequency does not stay constant at around 260kHz. It goes between approx 250kHz and 267kHz. Are there grounding issues I need to be away of?
Edit...part number should be MIC1557
bertus
Joined Apr 5, 2008
22,928
Is the temrerature stable?
What kind of capacitor do you use?
If you use a ceramic capacitor a np0 would be fine.
Also a styroflex foil type capacitor could be used.
Gibson486
Joined Jul 20, 2012
360
It should be stable....If there is any heat, it is is far away from the chip.
I used an NPO and then an XR7. Both produced the same results.
bertus
Joined Apr 5, 2008
22,928
What kind of resistors do you use?
Carbon resistors can change and make noise.
Metal film resistors will give a much better result.
RichardO
Joined May 4, 2013
2,270
100 pF is a fairly small amount of capacitance. because of this you need to keep the wires shot around it. Can you give a picture of your circuit?
Gibson486
Joined Jul 20, 2012
360
It's on a PCB....I think it may be the output...I have another circuit that I switch it with if I do not want to use the 555, so the output is sort of a long trace. It's really the only thing I can think of... I am thinking about making a circuit board via a panelized pcb shop, that way I can test multiple designs for cheap....
22,083
  1. What is the purpose of R7?
  2. What is driving the CS input?
  3. What is the purpose of C12?
You seem to be trying to do something other than what the chip was designed for. What is that?
Gibson486
Joined Jul 20, 2012
360
R7 is just a pull down to force it low when it is hanging.
CS is being driven by a relay contact the goes to 5V.
C12 is just a AC coupling cap. When I remove the cap, it makes no difference.
The circuit is going to a integrator to get a triangle wave.
22,083
Are you serious -- a relay contact!! They bounce (hi-low-hi-low..) for 20 to 50 milliseconds. No wonder the frequency output is all over the place. Congratulations, you've uncoverd a new feature of the part.
Gibson486
Joined Jul 20, 2012
360
Umm...it is only used as a turn on, turn off. I do not toggle it it every 2 seconds or something. If it says on, it stays on for 5 hours type of thing.
22,083
Well something we can't see is causing a problem, because your frequency stability should be better than what you have described. I would start with the application circuit in the datasheet with as few modifications as possible.
